Just purchased A 1993 bronco and My normal turn signals flash just fine but when I turn on my hazards they flash really fast like a bulb is blown But all bulbs are good. Is this normal for them?
That's not normal.
The multi-function switch (turn signal stalk) is a common source of problems, but that doesn't sound like your issue. It could be that a previous owner replaced standard bulbs with LEDs, which often causes hyper flash issues due to the wrong resistance.
You have TWO flasher devices, one on the front side of the fuse panel does the turn signals, one on the BACK of the fuse panel controls the hazard function, swap the two and see if the "fast flashing" changes, or invest $3 for a new one.
Yo Aemnky606,
Welcome!
Multi-Function Switch (MFS) Failure Causes; "...Mechanical components wear out or electrical connections are faulty; If the switch assembly is not operating properly, turn signals, hazard warning lamps, windshield wipers/washers and the headlamp beam selection may not operate properly. Related Components to Check; The switch itself, the electrical connections to the switch and the connections to each of the affected components (items such as turn signals, wipers, etc.)..."
Source: by MOTORCRAFT®
Multi-Function Switch (MFS) Cleaning; "Just hit hazard switch in and out for about a minute, which cleans the MFS contacts and presto"
via cawright3 at FSB
Hazard Flasher Lamp Switch
  1. Disconnect multi-function switch wiring harness connector.
  1. Attach ohmmeter to switch terminals.
  1. Cycle switch as required to test all functions of terminals under test.
NOTE: Closed circuit resistance between terminals is 5 ohms or less.
COMPONENT TESTING PROCEDURE
To Test​
Connect Self-Powered Test Lamp or Ohmmeter to Terminals​
Move Switch to These Positions​
A Good Switch Will Indicate​
Hazard Switch
385 (W/R) and 2 (W/LB),
5 (O/LB),
3 (LG/W), 9 (LG/O)​
Hazard Switch ON (Button Depressed then Released to FULL OUT Position).​
Closed Circuit​
ASAP, find out if speed control if equipped, recall worked out of was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
See this guide by jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
As you've done, for any Bronco questions or to chat about desired modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to participate due to scammers who preyed on our members ).
Our Forum FAQs includes for example, How To Upload Images To Posts & How to Use Search. See more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
Here is the 1993 Bronco Dealer Brochure in Google Drive @ 93Bronco.pdf
1993 Bronco Dealer Training Video via silver70 @
1993 Bronco, Venezuela Commercial @
Try to find time to participate in our current Full-Size of the Quarter Contest & Full-Size of the Year Contest @ Voting
See pictures & build info of each Bronco nominated.
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
