Figured I'd post here, in case anyone else has had a similar problem....my hydrocarbons are running around 566 at idle, and should be under 115...this confirms what I thought, it's running way too rich...
However my o2 (oxygen) is reading 1.9 at idle and should be closer to 0.
What I suspect is I could have 2 problems
1. In order for the cat to work, oxygen should be close to 0....with oxygen at 2%, I suspect that the cat is dying....
2. I'm running rich, real rich. 9-10 mpg's average....lower than what I should be doing in a 5.0. (also smells extremely rich) I was thinking o2 sensor, but it "looks" fairly new (def a bosche o2 sensor)...any of you know how to test this 4 wire o2 sensor??
Any other ideas from your experiences?? I'm not as worried about being able to pass smog now, as I am getting the run-rich problem to go away...as I know I have a few more mpg's I can pick up. I've got to get my hydrocarbons down quite a bit.
