IF you have the following symptoms on one side of your vehicles front lights...
1. Extremely dull headlight
2. Dull turn signal/parking light
3. Turn signal indicator (green light in vehicle) stays on when headlights are on
4. Headlight blinks when that side blinker is used
check your ground!!
all 3 lights on the front side have a common ground point... mine had the screw there... thats about as tight as I could say it was. Cleaned it and tighted it up... problem solved
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Bronco Forum - Full Size Ford Bronco Forum
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
