Hi all,
Normally, I wouldn't think this'd be a problem as I've fixed my fair share of heaters before, but this one has me stumped.
This is on my '81 Bronco.
First off, the thermostat is only a few months old. Engine warms up just fine. Radiator is around a year old or so.
I replaced the heater core last weekend. Before reinstalling it, I filled it with coolant and did the same with the two hoses that run to it to make sure there were no big air bubbles in the system.
Coolant is topped off. I've checked it a couple times.
Next, the '81 setup is all cable operated. There aren't any vacuum lines that have to do with the heater controls. It's a super simple setup (which is why I'm stumped!) I only have two options to change. Either the blend door is open or closed (hot or cold), or the air blows out of the bottom vent or the defroster. (I don't have A/C).
While I had the heater box off, I cleaned out any and all leaves, and checked the functionality of the blend door. It moved freely and moved the full range of motion. It also fully sealed when closed.
I've checked that the slider in the cab moves the door in it's full range of motion. I can hear the blend door 'thumping' into place when it reaches the limits of it's range of motion. I've also gotten out and seen if I can move the blend door's lever in the engine bay any further and I can't.
The hoses going to and from the core are hot.
Yet, I've only got mildly warm air coming out of the heater! It took a good 10 minutes this morning with the engine fully warmed up just to melt the frost off the windshield, and after a 20 minute drive the cab wasn't even warm. The air blowing out of the vent just isn't all that hot. In my other Bronco (an '84), it's hot enough to sting your hand, so I know how it should feel.
Any ideas on this? I'm really not sure what more to do.
