1 - 20 of 20 Posts
Seriously though, This Is my first Ford. Mine is a '91. It has a 302, EAOD, ? Transfer case, ttb, 4" suspension lift, 33" x 12.50", open differentials, 3.55 gears I think, Warn Premium Hubs, Flow master exhaust, high angle drive line, short radius arms on 4" brackets, single steering damper, rear anti-lock drum brakes.
I want to wheel rocks, mud, snow, and trail this Bronco. It's a daily driver also. I trailer my dirt bikes to areas to ride that also have 4x4 areas. I'd like to be able to pull off the trailer and wheel a bit, or a lot. I also live in the foothills of the Sierra Nevada Mountain Range in California, so there are allot of good trails really close including the Rubicon Trail! I also pack up frequently to go snowboarding, so I drive in the snow allot.
My goal is to part by part, upgrade any needed week links, as the factory part brake, or need maintenance. Some interests are: transfer case rebuild or swap for strength,air or electric lockers, SAS, better brakes, and any tire suggestions (fairly quiet, clean out good in snow, good sidewalls, 33" x 12.5").
So now you know what I know about it. Please help me make this truck into the monster it can be. I look forward to being a part of this forum. Thanks in advance for you help, answers:rockon , and even ridicule:slap .:goodfinge
FSB Pimpster & Recruiter
Welcome to our HOME....Here you will find everything you need to know about your Bronco.....
Dont forget to VOTE for Top 4X4 Site above and also for FOTM, Who knows, you may be a candidate some day....:thumbup :popc1:
Allcruisen :imp :usa
Not a dude
Sounds like you are pretty close to us. We are in Pollock Pines:thumbup
Welcome
Anyone have the part number for front and rear KYB Gas-a-justs for replacing original Pro Comp shocks that came with the 4" lift? I know the rear Pro Comps are es3000 but thats all.
How can I level this kit? The rear is a little lower then the front. How about getting rid of the blocks and adding a drop leaf spring bracket in the back?
Would I need another rear shock part #?
Welcome to FSB ~ :thumbup
You either have an AOD= automatic over drive with a 14 bolt pattern oil pan or E4OD = electric 4W over drive transmission with a 17 bolt pattern oil pan...
Additional help:
FSB "search" tool above yields tons of helpfull info from all of us here.
Haynes Repair Manual ~ ASAP, it's the bible here so we're all on the same page to help each other.
www.broncolinks.com ~ a wealth of tech info and diagrams on Broncos and F150's.
www.fordfuelinjection.com ~ FSB member owned, offers FREE vehicle computer fault codes and explanations for self diagnosis, requires using either an OBD-I or II Ford Code Reader with book which costs $29.99 at most auto stores.
www.supermotors.net ~ web hosting sister site joins FREE for additional "truck porn".
:beer
Calisa1969
Nice to see you here again it's been a while, what ARE you wheeling these days......I really miss your FABULOUS snow pics!
:thumbup
Discussion Starter #12
Nvr Been Bnnd
:doh0715: stop drinking so early...look at the post dates.
:histerica:histerica:histerica:histerica:histerica:histerica:histerica:histerica:histerica
welcome to FSB mines a daily driver also, so i am a little easy onit wish i could wheel it hard maybe when i find a cheap gas mileage car.
FSB's Dirty Jersian
If the rear is a little lower than the front, you can do a couple of things here-
1) find a lift block for the rear (IIRC they were made between 2-4", 3" being the most common)
2) do a shackle flip, and use OEM springs. This would probably give you 1" extra clearance in the rear over your front springs.
3) Buy an "add-a-leaf" pack, or singles. It will basically just add more leaves to your leaf pack.
as far as the part # for the struts, I'm unaware. A simple google search should help you out.
:doh0715: who picks up on a thread after all that time....too wierd, I should have known better, she doesn't even own that Bronco anymore...! :rofl:
FSB's Dirty Jersian
You guys are welcoming a member who's been here since 06 :doh0715:
Thanks 351w500
This is the introduction area. you need to ask your ??'s in the noobie tech section. or better yet go do some reading up.
1 - 20 of 20 Posts
