I was on my way home today and my truck started shifting funny, the OD light on the shifter was not on or flashing and the check engine light was coming on whenever it was shifting funny. I stopped at a stop sign about 1.5 miles from my house and it died. Got it restarted after about 10 tries and limped home, check engine light stayed on. I got home and pulled codes, Only KOEO because it wont run now. It had 1 code before 334, which is egr solenoid out of spec. That code isnt present now and I have 20 others. It makes absolutely no sense why I would have 20 all at one time, this has to be wrong.
117-engine coolant temperature sensor below minimum voltage
638-transmission oil temp. circuit below minimum voltage
126-map above or below normal
122-tps below minimum voltage
112-IAT sensor below minimum voltage
327-EGR valve below minimum voltage
654-not in park during KOEO
513
553-thermactor air diverter solenoid circuit fault
552-thermactor air bypass solenoid circuit fault
565-canister purge solenoid curcuit fault
556-fuel pump relay primary circuit fault
558-EGR valve regulator solenoid circuit fault
621-shift soldnoid #1 circuit fault
622-shift solenoid #2 circuit fault
631-overdrive transmission cancel indicator light circuit fault
629-converter clutch solenoid circuit fault or lock up solenoid circuit fault
626-coast clutch solenoid circuit fault
624-electronic pressure control solenoid circuit fault
111
It seems as if every sensor on the truck is bad and all the tranny ones too. The tranny was rebuilt only 5,000mi ago and I just put a new TPS sensor on on friday. All these electrical failures have to be related to something going bad. Computer maybe?
513
111
