This 94 has the 4speed automatic trans with over drive,manual shift trans case,302 and every thing I just mentioned is in excellent shape.the problem I'm having now is that after I drive about 6 to 10 miles and go to turn usually to the right,it feels like a brake is draging in the back.I had it do it a minute ago when I came home and had the wife come out and pull forward while I checked shit out from outside.If I touch all the hubs I feel it but really bad in the back wheels.Its like jumpy.I can jack it up though and the wheels spin fine, no brake hang up.Brakes are knew all the way around and I put knew hardwhere on and rebuilt the front calipers over this shit.Now the catch is it only does it when I have the wheel turned or I'm making a turn.Oh put new bearings in the rear to over this.The rear inside has what looks like a small clutch pack in it.Three tabs I believe on the disks I could see.Is it some kind of limited slip,tracktion lock or what?That is the only other thing myself I can think it could be.
Thanks in advance for any info,Steve
