what's it going in? If you're putting it in a Bronco with and E4OD you're limited to what EEC you can use, WAY1 or VEX1 will be your best bet. You can find the MAF assembly and tubes on any '93 or up F150 with a 5.0.
Unless you plan to buy Fireguys MAF adapter harness, you're also going to need to grab the injector harness as well.
