So, my engine had sat (rebuilt) for many years.
Once I finally got it started, it had a very slight leak from the drivers side rear area that seemed to come from where the head met the block. This was when it was warmed up.
I went ahead with the cam break in and by the time I was done, (maybe a little after...) the leak pretty much stopped by it self.
I never worried about it 'till recently.
I'm not getting an overheat condition (measured from the stock water pump port), but I do get freeway pinging under acceleration; when warmed up, even from an idle, I can hear some popping deep in the engine that sure sounds like boiling. When I feel the hose that bypasses the heater, I can feel popping that seems to confirm the boiling thought. This continues for a few minutes after shut down and I'll some times get a little dieseling.
Not that this issue just started, mind you but I just started to pay attention to it. I'd hear it before and, for some reason, never paid attention.
So, some things about what I have to work with:
I pulled the thermostat and still get boiling sounds even when the after market mechanical gauge reads cold. I cant seem to pin down exactly where it's boiling, but I can feel it most in the heater bypass hose.
The fan, which is a Mk8 E-fan swap works fine and is set to start low speed at 190, high speed at 209.
I checked the oil and dont seem to have any froth.
When I start the vehicle with the radiator cap open, I can see flow, so the pump should be good. Plus the pump is new. There ARE some bubbles but not right away. Only after a little bit of warm up time.
Radiator is a new unit, stock replacement with probably 1K miles on it.
While removing the thermostat today, I plugged the upper radiator hose and poured two gallons of water into the radiator and it came pouring out of the thermostat hole in the block about as fast as I was pouring it in.
With a new, tested, radiator cap the thing will fill the puke tank and overflow quite a bit of water. Enough that once it cools down and I look into the radiator, I can see the water level is JUST even with the cores in there. It likes to stay there.
I also dont seem to have any white smoke, acrid smell or water coming from the tail pipe.
So, it seems like I'm getting SOME indications of a head gasket (there WAS that leak, you see...) and some indications of a blocked passage.
There is obviously some boiling somewhere in the engine.
Any way to confirm either of these things?
I'd prefer to narrow it down a little before I start pulling heads to look at gaskets.
This is in my 79 with a 400. It has a Stealth manifold and a Edelbrock 1406, if any of that matters.
