1 - 10 of 10 Posts
would rock sliders from 80 up bronco fit our 78/79?
it looks like the rocker panel between wheel well to wheel well is shorter and also the frame tapers from the front to back more drastically in 78/79 than in later years.
any help is appreciated...
rock sliders? what? frame tapers? what are you talking about?ya lost me, but i will give a pic of mine
I thought I remembered reading somewhere that the frame to body height was different for mounting?
But the wheel base is the same right? So they shouldn't interfere but it sounds like your worried about aesthetics?
well the sliders im talkin about are 66" long..it looks like they will jutt out into wheel well openings(bummer)
going to pick them up soon and see for sure
I believe you have to cut a couple inches off the front of the bar, then close up the hole. Then they'll fit. The wheelbases are the same between model years, but the 78/79 has a larger wheel well opening.
Salt-Man
:notworthy
That Is Fuggin Sick Dude :rockon
That has got to be the sharpest Bronk I have seen yet :whiteflag
:notworthy1978custom :goodfinge :rebelflag You da Man!!
You truly Inspire!!
thank you that's the kind of info i was looking for..won't be able to pick them up till saturday
1 - 10 of 10 Posts
