1 - 20 of 34 Posts
so i cleaned my truck this morning washed down the engine bay.. go to start the truck and it starts right up.. then it stalls. so i start it again... same thing... so the 3rd time i start it and give it gas... it will continue to run untill its at a idle then it dies everytime... whys it stalling at idle after i hosed it down..? please give me some insight casue i gotta getto school tomarrow...
Designated Tranny Killer
you probly got your distributor wet
green ones make me horny
Dont play in mud unless you ready to reap the rewards. now you need to drain and change all your fluids like mentioned above. replack your bearings32r, cause there is probably mud in them. clean the bottom and hit all your zerk fittings with grease
the bruise
am i missing something? when did he say he was in the mud? he blasted his motor with water, why would mud in your diff, cause an erratic idle? you got something wet when you blasted it with water let it dry out, put a fan in your engine bay.
he washed it because he went mudding, see his other thread in general chit chat
Practicing Infidel
You done cracked the dist cap son !
Sixlitre
It's BTW Not AKA!
The advice about changing fluids wasn't neccesarily the solution to the idle problem, but a good general maintainance practice after a trip like his.
1 - 20 of 34 Posts
