I just removed all of the emissions crap including the can. Smog pumps been gone for years. What the hell is this???
I have the same plug laying loose after my smog delete… I’m pretty sure it was for the EVAPI just removed all of the emissions crap including the can. Smog pumps been gone for years. What the hell is this??? View attachment 197785
Was the ABS speed Sensor available on 1989 model years? I’m asking because I know for a fact I disconnected that plug when I removed my engine, and I never plugged it back up because I didn’t have the corresponding harness anymore… the only electrical component I didn’t put back in was the purge valve as far as I can remember. And if this isn’t for the purge valve, where is the purge valve connector . I would like to hook the EVAP back up.what color are the wires to it?
the purge solenoid is by the throttle body on most trucks. late years (might be 96 only) where the MAP sensor would normally be. so its not that. not part of smog pump
like i said im pretty sure its for 4WABS wheel speed snesor
4WABS was only 94+ broncos. his being a 95 would had itWas the ABS speed Sensor available on 1989 model years? I’m asking because I know for a fact I disconnected that plug when I removed my engine, and I never plugged it back up because I didn’t have the corresponding harness anymore… the only electrical component I didn’t put back in was the purge valve as far as I can remember. And if this isn’t for the purge valve, where is the purge valve connector . I would like to hook the EVAP back up.
