1978 Bronco, 351M
8 years ago the engine was in pretty good shape. It has been worked on a few times since then and there appears to be something missing now. specifically, it appears to be part of the throttle body. i need you to help me figure that out.
here's the engine 5 years ago.
http://farm5.static.flickr.com/4005/4683597643_38c110efd4_b.jpg
the red circle shows the piece that's now missing. here's another angle.
http://farm5.static.flickr.com/4017/4683597609_acd3c1ba6b_b.jpg
here's the engine now (fuel hose has been replaced since i took the picture).
http://www.flickr.com/photos/[email protected]/4679976415/sizes/l/
here's another view.
http://www.flickr.com/photos/[email protected]/4680609336/sizes/l/
is it a throttle position sensor? or a return control device? or both? neither?
I can't tell you what it is, but I can tell you that I highly doubt it's a throttle position sensor.
that is unless that carburetor is masquerading as a fuel injection system...
of course I could be wrong, forgive me, I'm bored...
If I had to guess what it is, I would say it is either some type of high idle critter to help with warming up the engine, or a vacuum control of some type.
either way I don't think you "need" it.
I am not sure, but if your carb has been sitting for 8 years I doubt it is good to go. Likely is going to need at least to be rebuilt or replaced.
You have a carb, not throttle body. The part that is missing is the idle stop solenoid. Parts stores carry them.
Thanks so much Ranger. I'm on it!
The bronco has been sitting for about a year (I know...I do feel guilty), but still starts and idles just fine.
Can I bother you for one more answer? What is the function of the idle stop solenoid?
Thanks again for helping me learn!
My 78 came with factory ac. On mine, that part kicked the idle up, when the ac was turned on. I used mine when I did the OBA, to raise the engine speed, wheen I was pumping air. I didn't even have to rewire, just slide the climate control lever to ac, and it engaged the solenoid.
Side step it
If I'm not mistaken it also kicks it up when it's cold too...if you don't have a automatic choke!
