1 - 4 of 4 Posts
between my carb and the firewall on my 82 351 there is a metal component attached to the intake. it has some vacuum ports (four i think---) that all point to the top of the engine. one of the ports does not have a hose on it. i am hoping someone will tell me the name of the part and it's function as that will help me try to figure out if it should have a hose connected to it . thanks for any help offered.
vacuum tree? If you still have a diagram under your hood, it will say what these go to. (or a manual) It sounds like that is what it is. I have a fuel injected engine and I'm not sure if they are the same in that area.
Pictures are good too!!
thanks. there are several vacuum lines coming directly off the manifold and split with plastic t's----so was not sure if this had another function. thanks a bunch for your help. i have always "played" with chevys-----dang if i don't feel like i am starting from ground zero with this project.
1 - 4 of 4 Posts
