Hey guys,I took my 93 Bronco on its first long trip yesterday.I always knew it had a slight oil drip but Iwasnt worried.Anyways I was cruising along doing about 65-70 and I noticed smoke pouring out of the rear of the truck from underneath.it only happened when it was in the passing gear or if I was going up a slight grade in overdrive.I pulled over and it wasnt trans fluid or anything.I dont believe its the rear seal.My valve covers are dry.But looking closer it seems like it is coming from above the starter.Leaking down onto the pipes and all over the trans.IS there a seal or something up there that goes?I cant think of anything and its been to cold to crawl up in there.Just wondering if its a common thing on these.BTW its a 5.0.Thanks!
