BACKGROUND: I just rebuilt my 302 inside my apartment and it fired up on the first try
It was my first rebuild and I was very very careful about bearing clearances and rod cap torque, etc. I spent several months reading and researching to make sure I got it right. I converted it to a roller cam and lifters so I bought the 302 H.O. rebuild kit from FlatlanderRacing.com and specified that it was a truck instead of a car. A side effect of this is that it's now a 351 firing order so it idles a little rough because the injector timing is still 302. I've done 3 oil changes since I first started it and the engine only has about 350 miles on it.
After timing it and other miscellaneous adjustments I can't figure out what this noise is coming from the engine. I pulled off the serpentine belt and made a video of the sound.
http://www.youtube.com/watch?v=MQx2qPAhvKs
It kind of sounds like if you were to strap a stiff wire brush to a wheel and spun it rapidly. Like a scraping noise.
FYI: I know I've probably got exhaust leaks on the passenger side because I snugged up the header before I got some of the bolts started so I'm missing 3 bolts where the header pipes made too much of a bend to start the bolt. I can hear those exhaust leaks with a tube to my ear and they just sound like little farts.
This noise is much louder and seems like it's coming from the front of the engine. When you're standing in front of the motor it sounds like it's coming from the driver side but if you move to the driver side it sounds more like it's coming from the front of the engine. The noise gets faster as engine RPM increases.
There doesn't seem to be any power issues except it seems like it has less torque than a truck should have going uphill but it screams on the interstate. I think this is due to a combination of the H.O. cam, C6 tranny, and maybe gears with the 33" tires. I have no idea what gears are in it since the door sticker is gone.
I've put a poor man's stethoscope (long breaker bar) to my ear and touched various parts of the motor but it all sounds like it's humming nicely. I can't hear any loud knocks coming from the engine so I don't think it's knocking.
Would you be able to hear a bad bearing with a stethoscope?
Any sort of noise makes me really nervous now that I've been intimate with every inch of the engine. If it's a bearing or a valve train issue I just want to resolve it right away before I do any more damage.
Thanks for any input as I'm excited to get the Bronco back on the trail.
