not banned
I am towing an ~7k lbs tandem trailer presently.
This AM things started off fine, but as the day heated up, (my temp gauge didn't get off low) I had a recurring problem. while under load (up hill) i began to have a "knock" or rubmble. I chalked it up to post detination and havign done the 6L tune up. I started buying 89 octane gas, in hopes of aleviating it.
but the real problem was.. not specifically while under load, but 3 times, it began lurching, as if the fuel was vapor locking intermitently, or the ignition was overheating and sending spark in "bursts". so, i replaced the carburetor with a known good one, replaced the fuel filter, and the ECM with new ones.
The problem recurred.
Of note, the last two times, after i slipped it into NEUTRAL, and back into DRIVE, the problem resolved. I still pulled over, and plan on seeing AAMCO in the AM.
any ideas? pelase. :{
