alright, so i took off my hub and rotor and switched vout the rotors and im ready to put them back on. where and how does this bearing go back on? does it go in after the rotor and hub or before the rotor and hub? and in which direction?
thasnks
looks like the outer bearing....it goes in before the large round nuts go on. but did you regrease or replace the inner bearing? and did you change the seal? both should be done before even installing the rotor/hub onto the spindle.
yes...torque the first nut to 50 pounds, back off 45 degrees, install the washer (make sure to line up the little pin, you may have to move the nut to do so.) and torque the outer to 150 pds.
Looks like you didn't repack the bearing and you should repack the inner bearing as well as the spindle bearings. The bearings only fit one way, you CAN"T go wrong.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
