i put this on the an old tech section thread, but later saw i probably should have come here first. :duh
i just purchased a 1991 bronco 4X4 5 spd 302, last weekend. only has 89K on the engine. among other things, my driver's side power window will go down, correctly, but not up ... motor seems to work fine, and i can raise the window manually with both hands on each side of the window, but slips back down while driving.
what i'm seeing here is that i need to replace the torque pin or regulator gear plugs. is that correct?
the last power window problems i had was a 1963 Studebaker Avanti, and it was a while ago...
tia. and will have more questions if i can't find the answer using the "search" function.
ppowkl03 is online now Report Post Edit/Delete Message
