the origional problem to be fixed
note that you can see through the piston onto the cement floor of my garage. The culprit: an untorqued head bolt by the mechanic who did it last (not myself). The piston fell apart and got little pieces all over the place, such as in here
Time to rebuild
So I bought a 351w rebuild kit from summit. Fastforeward to this past friday. I got this far
the engine wouldn't turn over. It took me forever and one embarassing post to figure out why (although the post did little to remedy the current situation, it did help me to aviod a future situation and I appreciate all the help from those who did, despite my retardedness). Turns out that summit sent me a 302 rebuild kit, and the bearings are much smaller. Went out and got some new ones, that luckily are the same brand. And got once again to that same point. Called it quits for the night.
Saturday I started at 1230 because thats when it came in. I finished rebuilding the engine. I have a picture of it, Ill post it tomorrow once I get my hands on it.
Sunday I got this far
and then I got this close
but it wouldn't go, so I gave up around 900 (note: the picture was not taken until this morning)
Monday I woke up and started working. I worked for a short while till I found that the torque converter was not going on all the way (I don't know why I didn't figure that out any sooner, theres been alot on my mind other than what I'm doing), I pulled it out and realized that when I pulled the engine back in october that I had stuffed a paper towel down the hole to soak the tranny fluid up. Well I quickly found that to be the problem, rid myself of the paper towel, and put it back on. After a while it finally went into place and I began to bolt it up. Then I bolted up the new motor mounts, and began connecting things until about 900 when I decided to quit because I didnt' have any oil(other than the quart that was already in there) or coolant so I stopped it here
Those of yall who were in north texas, or pretty much anywhere north of austin, know that it was really really cold and that it was snowing/icing well this was the only thing that kept me warm as I didn't have any thick jackets that I felt like ruining with oil stains. I got a propane heater that looks, sounds and feels like a jet engine.
I was nice and warm the entire time
ok supermotors is being mean so I'll update those pics asap
As for the rest of the story... I wont have time to work on it till thursday. By then I should have what I need to try to get it started, although I doubt it will
Time to rebuild
