maybe i have abused mine in the 3 or 4 times i have used it as a "winch" but it is now not working under a load. I have determined the problem to be at the handle where it mounts to the climbing gear, there is a Pin but one side is rounded down and when you push the handle down it just goes over this and then doesn't push the climbing gear or whatever it is called upwards.
Maybe i can get a shot of it later to specify exactly but i don't see anything in the Hi- lift acc page for it. So if i can't buy it, doesn't it matter what type of pin i use, Ie is this one a shear pin or specifically rated?
http://www.hi-lift.com/products/parts_services.htm
well upon reexamination it almost looks like 8 or 7....
