I have a question for you guys. Right now my bronco has really low oil pressure which I believe is from a clogged pickup tube/screen. Since I will have the pan off anyways I will be checking the bearing clearances and replacing the oil pump. This is where I need you help. I know that high pressure oil pumps put extra stress on the dist. gear, and oil pump drive shaft. I also know that 302/351w have good oiling systems, but will this thing give any benifit in my oil pressure? The website says that it will boost pressure by 30%. I know that if I buy this that I will need a hardened dist drive shaft also.
