1 - 3 of 3 Posts
Thinking about moving the tie rod on top of the knuckles
How much lift do I need to do this?
What does it take to drill out the knuckles for 3/4 ends?
78 bronco. Dana44
Addicted to Junk
I dont think it takes any lift. You'll just have to shorten it up a bit.
You'll need a sharp drill bit and proper reamer to add the cone shape. The bit should only be big enough to barely fit through the current bigger end of the hole on the bottom of the knuckle. A 3/4" bit would be too big.
1 - 3 of 3 Posts
