Might vary a bit depending on the engine type and how "built" it is, but I'll share my settings. Mine is on a 10:1 compression 460 with iron heads that made 450hp @ 5k rpm on the dyno, for reference.
12.5:1 @ WOT
13.5:1 @ idle
14.9:1 @ cruise
My initial ignition timing is set @ 15 degrees.
Max timing is set @ 34 degrees.
I haven't manually tuned the curve on either the AFR or the ignition timing other than using the settings on the handheld. I don't currently have a computer to tune with, but the settings I have seem to be doing ok. I'd like to adjust the timing curve the most as it's a very short, very steep curve going from 15 to 34. Something like 1500-2500 rpm it goes from 15-34 degrees.
12.5:1 @ WOT
13.5:1 @ idle
14.9:1 @ cruise
