1 - 20 of 20 Posts
aka: bigford84
so i need/want a snorkle on my 89 fsb... i found a homade snorkle on google,the guy that did it is BRONKO806. i emailed him to ask ?s but no response,so im going to post a pic of the rig and ask you guys the ?s
what size pipe is good?
how would i mount it to the body?
were do i get the top peice?
what about when it rains?? dont you get water in there??
those are the ?s or does anybody have a better idea/planes on how to do this?? thanks for your help
aka: bigford84
well i dont like to play in deep water. my problem is i went through 2or3 feet of water slowly and started pulling water into the intake and stalled out.
Driving Stuff Henry Built
i had a Land Rover Defender had one of these in Guatemala and it comes in MAJOR handy when your windshield is halfway full of water (wanna see some crazy stuff? look at jungle mudding, now THATS crazy stuff you wont see everyday)
AND el kabong, what do you have in your bronco? it looks real clean san felipe bar on it looks nice too* i have one just like it!
The 73? Thanks. It's beat up pretty bad, but that's what fit my budget. I've been gathering replacement parts for it, but haven't done anything with it yet. It has a 351m. More on it here. My 90 has the 351w.
how would i b able to do this man ive been wanting to do this for my bronco 1986 5.0 carb
QUOTE]
yo JOSE,
Here are some for carb'ed Broncos; But make sure you have a flexible section between cowl or fender or hood an carb filter housing to allow for engine vibes
Installation through fender, Safari #SS17HF info & pics in an 82
Source: by Daryl P (The Bronc) at http://www.supermotors.net/clubs/superford/registry/54/57802
pics though cowl in an 83
Source: by Hal L (zeus) at http://www.supermotors.net/clubs/superford/registry/4309/17867
pics though firewall in a 79 460
Source: by muddinmike (Mike H) at http://fullsizebronco.com/forum/showthread.php?t=65695pics though fender in a 78
Source: by Swampwalker3 at http://fullsizebronco.com/forum/showthread.php?t=61711
More Snorkel LINKs in my site @ http://www.broncolinks.com/index.php?index=173
GL!
QUOTE]
yo JOSE,
GL!
Hey man thanks alot that exactly what I wanna do but I think imma go with like the one thru the firewall that was I was thinking of doing frm the begining I only have one Qs where would I b able to get the little chrome thing that goes on top of the car?.. nd once again thanks alot for ur help;)
yo JOSE,
Humvees use a "pre-filter box" @ tp to keep most water out, but is largely used to stop large particles such as birds and body parts from clogging da air filter.
Snorkels should have a bend at top
here is a Hummer type snorkel top
http://www.sy-klone.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=SI&Category_Code=S9
Also, look for Safari snorkels on e bay, etc.
as our buddy Chris B used (he has EFI, but you can adapt to carb air cleaner housing as others have done)
Installation through fender, Safari #SS395HF in an 85
Source: by Chris B (Blue, bronco boy) at http://chrisb.users.superford.org/Bronco/Projects/Snorkel/Snorkel.html
I wanna say i've seen guys use 4" sewer pipe. Cheap and easy. Also don't forget the seal the distributer. I've actually had more issues with that over the intake getting wet. I usually put a ring of silicone around the cap when I change it. Let it dry overnight, then install the new cap. They also make dist. boots. ALso, after hearing alot of opinions about this mod, I think I would make a quick disconnect for daily driving.
If you use the PVC or black sewer pipe option, make sure your connections are going to be good in the engine compartment. I made a cold-air filter for my old 93 Explorer and the heat in the compartment started to warp the flange fitting I adapted. It allowed unfiltered air to get in, so I had to remove it and go back to the original box filter.
I would recommend using metal inside for any connections. I have seen some adapters at the local parts store (Advance Auto I think is where I saw them) for metal intake tubes with various bends. You might want to see if there are any that might be the correct diameter there.
F.O.T.M. - MAY 2014!!!
What material did you make it out of?
yo JOSE,
hey miesk5thanks alot for all ur help ur very helpful i jst realize that i misspelled the last post :doh0715 what i was trying to say is where can i get the pieces that goes on top of the carburetor the adapter like the one on the link u provide me that goes into the fire wall thanks alot again
I used a Black PVC Toilet Flange. Went from 4" pipe inlet to flange I could attach the Cone filter to. In theory it worked well and fit tight, but in reality the material was not up to a standard for the inside of the engine compartment.
Man of endless projects
i didnt want to make a poentioal problem on my 88s snorkel so i bought a spectre carb plenum part# 9849. alittle RTV and i have a perfect seal on the carb and its perfect size for my PVC pipe. problem is that i did cost quite abit but since i like deep water its worth not to hydrolock another motor and dam does it work
for the air cleaner i modified a MAF air cleaner box from an expedition. i modified it alot but ill one day make a writeup on it. for temporary use on a dry non-rainy day i used the cheap Spectre cold air cleaners and stuck it on the top. however if its rainy nothing stops water from going inside
...where can i get the pieces that goes on top of the carburetor the adapter like the one on the link u provide me that goes into the fire wall thanks alot again...
YO JOSE;
As KINGFISH advised for the $ for that plenum;
or see pics though firewall in a 79 460 (modify location, etc for your Bronco)
Source: by muddinmike (Mike H) at http://www.supermotors.net/registry/4950/17762
See how MIke mtd the Cone Filter inside cab?
That is how those BAJA type racers do it; will be loud tho & windows will need to be down all the time; have seen some mtd thru cab roof too
YO JOSE,
As KINGFISH advised; $$
Spectre/90 degree tube low profile single intake plenum for use with carburetor or throttle body
Part Number: 757
Clamp Color / Finish: Polished
Clamp Material: Stainless Steel
Clamp Quantity Included: 2
Clamp Type: Worm Gear
Coupler Color / Finish: Black
Coupler Material: EPDM
Coupler Quantity Included: 1
Intake Pipe Color / Finish: Polished
Intake Pipe Material: Aluminum
Intake Pipe Outlet Length (in): 4
Intake Pipe Outlet Shape: Circular
Intake Pipe Outlet Width (in): 4
Intake Pipe Ports: None
Mass Air Flow Sensor Adapter Included: No Mass Air Flow Sensor Adapter Required
Vacuum Tubing Included: No Vacuum Tubing Required
http://www.autozone.com/autozone/accessories/Spectre-90-degree-tube-low-profile-single-intake-plenum-for-use-with-carburetor-or-throttle-body/_/N-26kc?itemIdentifier=315735_0_0_
pics though firewall in a 78 Mud Bogger Project
Source: by Salt-Man at http://7879blueovalbronco.com/forums/showthread.php?t=746&page=2
See how Salt-MAN used common matr
See pics though firewall in a 79 460
Source: by muddinmike (Mike H) at http://www.supermotors.net/registry/4950/17762Mike mtd cone filter inside cab below dash; will need a lot of air,
one Pic for example;
Will be noisy too!
so windows will need to be down all the times as Off road racers do
Some have mtd filter using a lot of tubing in cargo area.
Air Cleaner Housing flex tubing to cowl; same mod for thru firewall
by hal
Spectre/Air duct mounting plate
Part Number: 8148
Spectre® couplers, tubes and related components allow you to design your very own custom cold air intake system. •Universal modular air intake
•Light-weight, high impact abs plastic, mounting plate has outside measurements of 3 3/4 In. x 4 In.
•Universal application
•Lifetime warranty
http://www.autozone.com/autozone/accessories/Spectre-Air-duct-mounting-plate/_/N-265w?itemIdentifier=422450_0_0_
Spectre/Black air ducting
Part Number: 8741
http://www.autozone.com/autozone/accessories/Spectre-Black-air-ducting/_/N-25h5?itemIdentifier=422454&_requestid=3354318
•Flexible
•Conforms to countless positions
•Retains position with memory-flex
•Thread pieces together for longer needs
Air Duct Type: Flexible
Diameter (in): 3
Item Grade: High Performance Part
Length (in): 28
Material: Polypropylene
Package Contents: Duct, Boots
man that flex pipe u posed miek is really crappy. i tried it when i had my original EFi 302 in my 88. that flexpipe was useless and wuld get spilts through the pipe
yo KF, Thanks for that info!
I wouod go thru a yard and look for proper sized flex pipes from other vehicles
1 - 20 of 20 Posts
