Go here http://www.poisonspydercustoms.com/index2.html and look under Suspensions
Don't double-nut it, and definitely don't use any plate of any sort, on the end of the tubing
aaahhhhhhhh.....no. it's seems you have to reconsider what you think makes a joint design strong.95bronc said:![]()
:toothless :toothless
Well..................I guess so long as you can hammer it in square. I'd wanna use a press personally.mda said:You don't cap the end of the tube with a steel plate. The tube is sized to allow one nut to be hammered into the tube.
It's worth it to go back and read...you have to have it mounted to top and bottom of the axle tube to affectivly stop wrap...mounting to just the top or bottom allows the axle to wrap in the oppisate direction...(mounted in the middle stops nothing, except maybe articulation)RTM said:I didn't read every post in detail but I keep thinking of a singal bar or triangle mounted to the center of the axle.
I kinda like that, Kieth has some good points about the extra work involved, but with the right planning, this looks very capable..collinsperformance said:i still like the bambar idea
Speaking from an engineer's perspective, the drawback to the BamBar setup is that it puts the front half of the leaf under the same sort of compressive stress as the products that seboh is talking about. The only difference is that the force is reduced -- it's inversely proportional to the vertical distance between the leaf and the horizontal tension link. Don't get me wrong, it's much better than a link bolted to the leaf, or a single horizontal link that bolts right to the top of the differential housing.Blaze said:I kinda like that, Kieth has some good points about the extra work involved, but with the right planning, this looks very capable..
I dunno, guys do it on YJ's and I've even seen at least two TJ's that converted to rear leafs and then did something like this. Now that's severe lack of room LOL. I think with anything BUT the E4OD you'd have plenty of length.Chuck said:The problem you have with them in the Bronco is a severe lack of room to make them long enough. As was mentioned above, this is particularly fun if you suffer from a case of E4OD, a problem I share. However, as a rule, the amount of anti-squat you get is inversely proportional to the length of the torque arm. The further you can get it up the chassis, the better.
Chuck said:Speaking from an engineer's perspective, the drawback to the BamBar setup is that it puts the front half of the leaf under the same sort of compressive stress as the products that seboh is talking about. The only difference is that the force is reduced -- it's inversely proportional to the vertical distance between the leaf and the horizontal tension link. Don't get me wrong, it's much better than a link bolted to the leaf, or a single horizontal link that bolts right to the top of the differential housing.
Ladder bars definitely aren't the way to go if you actually ever plan on doing anything more than Mall Wheeling -- they actually turn the entire rear axle and housing into a giant, very stiff anti-sway bar. Say goodbye to articulation -- and possibly to the plug welds holding your axle tube aligned in your housing, depending on how the ladder bars are arranged and the weight of your rig. Leave 'em to the drag racers.
Despite the anti-squat drawbacks, torque arms (the single central ladder bars of which there are several shots in this thread) are generally still better. The problem you have with them in the Bronco is a severe lack of room to make them long enough. As was mentioned above, this is particularly fun if you suffer from a case of E4OD, a problem I share. However, as a rule, the amount of anti-squat you get is inversely proportional to the length of the torque arm. The further you can get it up the chassis, the better.
Just my $0.02. :thumbup
LOL, thanks. I figure I might as well try and be helpful to someone, since I'm too dang broke to do much to my own truck right now anyway. :toothlessJahWarrior said:Welcome to FSB, and a good first post too :thumbup
Yep, that will definitely reduce the effect. It doesn't change the stiffness of the axle "anti-swaybar" itself, but by bringing the front ends closer together, you reduce the amount of axle twist (or bushing deformation) you need for the same angle of body roll, which reduces the effect that the bars have on the truck. However, if you carry that to its logical conclusion -- bring the ends of the bars all the way together to a single joint -- you end up with a torque arm anyway, and ALL the bind goes away.montster said:if you set up the ladder bars angled inward a bit, made them arc very close to arc of driveshaft and give them the ability to rotate at the front shackle would that not reduce the trac bar effect? still a bit cold and snowy out here to crawl around under the truck to see real world effect just cause it seems ok on paper dont really mean sqaut but paper is all I have till it warms up
