Hey, I'm restoring the tilt steering column in the bronco, and I can't figure out how to wire the horn button. The truck didn't have the stock steering wheel when I bought it. I've replaced it with a stock version, but I don't know how to hook up the wiring because the 2 wires for the horn are cut off half way up the column. If I remember correctly, when I bought it, these 2 wires were hanging out of the column so you could touch them together to get the horn to honk.
Is there some kind of connection I should be looking for in the turn signal or something? I've looked all over and cannot locate a place to plug a wire. I'm pretty sure I don't wire it directly to the horn button because that would twist my wire all the hell :toothless
