1 - 20 of 21 Posts
I'm trying to get off the starter, and the bottom bolt and nut came off pretty easily. I couldn't get the top bolt off and it looks like its stripped. Its in a pretty hard area to get to... how can I get it off?
Suppose you can't cut it off with an angle grinder or dremel?
Yes, I have tried with both. The bolt is definitely stripped.
I would have a hard time getting at it to cut off the head, but even so, I still need to get a new bolt in there, so that defeats the purpose.
R
Guest
You could look into one of those bolt-out tools. I haven't tried any personally but the alternative is to cut the head off then take a small drill bit and drill into the remaining shaft, then try rotating it out.
Practicing Infidel
Y'all mean this he-are thang he-are ?
Last resort IMO
Sixlitre
Practicing Infidel
Ubermich said:
Correction:
Y'all meen this heerthang heer?
::tip hat::
Thanks Ubermich
I ain't schooled right in Southern as I's a Canajian
Sixlitre
Last resort IMO
Sixlitre
Honestly, this would be my FIRST resort for a damaged bolt or nut. I bought a set about 2 years ago, and they work amazing. I've been able to break rusted bolts out that wouldn't budge with a breaker bar with these with very little effort. Im not sure how they design works so well, but it does.
This is what I recommend though, so good luck.
i concur those work wonders and nice ride :beer
Sixlitre said:
Last resort IMO
Sixlitre
AMEN!
I just used the exact set last night to remove the BOTTOM starter bolt on my 94 Bronco - which was also stripped & rounder than a fat lady's ass.... The previous owner must have used %$#@! Fisher & Price tools for doing his repairs...
That above set works excellent and the tool removed the stripped bolt on the very first try!
Last resort IMO
Sixlitre
Not last resort, IMHO, would be the first tool Id grab for this. If the head is stripped, you gonna need a new one anyway!!
Ive got the Irwin equevelent of the Bolt Outs, and *love* them, have saved my ass at least *3* times, well worth the investment I made in 2 different sets!!!
:chili:
Ran in to this problem about a month ago, tried using the stripped bolt removers but not enough grab or room to work with it. I used a dremel to cut the head off and used an motor head stud remover to take it out took in no time at all. I used stainless bolts to replace the factory ones.
good luck
Jay
JaysBigBronco said:
.... but not enough grab or room to work with it.
For the life of me, I cant see why... but okay.
The reason these bolts are more prone to the heads stripping,is that the depth of the head of the bolt is much shallower than a standard bolt.
Practicing Infidel
Wonder if the exhaust heat from the passenger's side headpipe makes things worse ? I always lather the crap out of the bolt threads with anti-seize before they go back in.
Sure like Sewiv's idea of taller headed stainless bolts for next time. Being a different material they might not seize to the hole's threads as easily.
Sixlitre
Discussion Starter #20
Sorry it's been so long since I've responded. I bought myself a set of bolt out removers, and they are not working... it's just too stripped. I tried using the #5 which would be correct for the size, but it just slips right on and doesn't grip. I tried to hammer on the #4, and it wasn't able to stay on. I bought an adapter to make my cordless drill a right angle setup, so I am going to try and drill out the bolt head tomorrow.
I will definitely be looking into the SS starter bolts as well. Thanks for the info on that.
1 - 20 of 21 Posts
