1 - 20 of 23 Posts
Okay fellers today I got an engine and it is locked up from sitting for years. My uncle that gave it to me said he's had it soaking in Marvel Mystery Oil for a few days. He said he can't get it to turn over with a cheater bar, so he gave it to me. Perfect timing to get a free 304 for my heep, but how would you go about freeing it up? I've heard mixing atf and kerosene will do it, but I figured maybe you guys have been through this before. Any ideas? Thanks in advance guys:thumbup
Dead Horse
normally its just a little rust around the rings, just keep trying what u did, thats what i always do in shop class
well senoir stupid, a buddy back home has a 50's jeep that he got from his gramps. the engine was locked up so we took the plugs out and pourd trans fluid in and let it sit for a few days. then we chained it to the back of his truck, left it in 1st and dragged it down the road till it freed up. took a little work after it freed but it runs like a champ.
Banned
I'd let some penetrating oil (Liquid Wrench) soak in the spark plug holes for a few days (re-applying each day), then top it off with some motor oil when you're ready to try it. If you can get a bellhousing & starter mounted to it (assuming it still has a flywheel attached), that would almost certainly break it, and you wouldn't risk shearing the harmonic balancer bolt.
As fun as that sounds, I think my uncle would get pissed if I was dragging his Commando around:histerica
Excellent idea:thumbup I got a spare flywheel and bellhousing and I can do this w/ the engine on the floor of the shop.:rockon
If you can't bust it loose with a cheater bar on the balancer, a starter isn't going to budge it either :banghead However, since you do have a flywheel, you can get a lot better leverage against the flywheel ring gear than you will with the balancer bolt.
Your worst case scenario will be to pull the heads and use a 2X4 against the pistons with a big hammer. The shock will break the rings loose from the cylinders. I helped a guy resurrect a couple engines from a 1942 ChrisCraft boat this way that had been siezed for 30 years. If the rings are rusted in this bad, plan on an engine overhaul as you'll have a groove in the cylinder walls when you're done.
that is what we did to free up an old 351m. got a piece of 4x4, cut off the corners, let it soak for a couple of hours with that pb blaster stuff and hammered away. worked really well.
Banned
The starter can apply a LOT more torque to the flywheel than the harmonic balancer bolt can withstand from a cheater pipe.
ASSSSS-HOOOOOLE
Specially if you can get ahold of one of those high torque starters, those things could rip you in half.
Roller rockers are gay
this sounds like the most fun. :twotu:
I watched something like this on the Sat TV show "Trucks" and I think he was working on an old military looking yellow Chrysler Truck supposedly sitting in a field, Liquid Wrench or WD 40 was what he used I think. Let it sit for a few days to losen the rust around the rings, tune it up and it should fire up. Good Luck!
ASSSSS-HOOOOOLE
Are you talking about the Sergeant Rock project?
o[|||]o
Yup. Thats the one.
1 - 20 of 23 Posts
