1 - 12 of 12 Posts
What do you want to change about it?
i have to, it is rotted out and does not secure the y pipe to the exhaust manifold. bolt goes right through it. this what the cause of my exhaust leak. i thought i had a hole in the manifold and it was only the flange rotted out and the y pipe seperated from the manifold, oh well i guess i did not need new headers!
not ghetto as in cheap I meant like something that is actually a 2 peice flange designed for what i am in need of.
Satyr of the Midwest
They DO make such an animal. I saw them at Murray's last time I was there shopping for exhaust tubing. It's called a flange repair kit, and they're intended for use on flanged catalytic converters. In YOUR case, you're probably going to be farther ahead just getting a new piece to weld on to the Y-pipe, which includes that stamped piece AND that flared part.
Discussion Starter #11
thanks,
thinking i am just going to replace the entire exhaust. don't want to deal with cutting and welding and it could use replacement
1 - 12 of 12 Posts
