1 - 13 of 13 Posts
Do I need to get a different one? or can I use the existing drive shaft? What parts do I need?
Why I can't do it? I'd rather just buy a new one, probably cheaper than payin someone $60 per hour to hang out under my truck all day.
what?
you mean change the length of your driveshaft, as in extending it right?
unbolt it, tell them how much longer you need it, they will cut it apart, put in a new longer tube, and then weld it back toghether straight, then balance it. probably cost you $100
or you coul dbuy a new one for $300 or since they have to buy all new parts. slip yoke, stub, CV head, joints....
if you are asking this question i doubt you have the machines(lathe, and balancer ) to do this job right
:cry
Discussion Starter · #8 ·
:cry :cry :cry :cry :cry !!!!!
Banned
I just so happened to take mine in last Friday and they are charging me $125.00 to extend it. Its better that you let a pro handle this one than try to do it yourself. I have seen really funny homemade drive shafts that only end up breaking after a few off-road miles.
Only if its broken.
Sure, as long as it isn't broken.
None, as long as nothing is broken.
Now that we are done playing games, advise us as to what you are doing, so we can answer your question properly. :twak
If you just want to lengthen your shaft for the hell of it, yes you can. I would advise against it, unless you know what you are doing, cuz keeping it balanced will be a biatch.
Satyr of the Midwest
:stupid I was trying to get a handle on that as well. Why do you need a longer driveshaft? A lift kit? Moving the rear differential back?
for a new drive shaft for my car carrier it costed me 240with tax. need it and it is impossible to find a replacement as it is a custom ds in the first place.
if its not broke dont mess with it!
1 - 13 of 13 Posts
