1 - 15 of 15 Posts
Sway Is My Fan Club.
My brother got moved into his new house and I'm taking over his room. There's a 4"x2.5" hole in the sheetrock. Can I use a piece of screen and then putty over it, or do I need to make the hole square and use a patch of sheetrock?
On a side note in my brother's new house, the first thing he points out to anybody is that the Swinger fits in the garage and the garage already has a 220V outlet wired for a welder or big ass air compressor. :thumbup
I am assuming that this is a "fist" sized hole. If this assumption is correct that would more than likely put the hole somewhere between four and 5-51/2 feet off the ground. Simply take a picture of your Bronco, blow it up to a 8x10 frame it and place it over the hole.:thumbup
Two ways to fix that, both require cutting the hole larger, to a square, or rectangle shape...
1) use two small pieces of plywood, as backing. Slip the pieces behind the hole's sides, and screw thru the sheetrock, into the plywood. Then screw a patch to the plywood backing.
2) the California patch - cut the hole's sides to a bevel, and cut the patch with a bevel to fit. Use drywall mud as a 'glue' and set into place. Use long strips of painter's tape - the blue masking tape - and let it dry
Personally, I've always preferred the plywood backing (edit...)
Haha, yeah that might work. Actually its about 3 feet from the floor. Maybe he kicked the wall? I don't remember how the hole got there. :shrug
Thanks David, I may try the plywood method. The room needs painting real bad, so if I fix it, I'm gonna do it right and make the room real nice. I plan on painting it back blue like it is, Ford blue, and hanging up all my Ford posters and signs and stuff.
In Front of Jopes
This makes me think of the part in "Shawshank Redemption" when the Warden rips off the poster and discovers what Andy did.......:lolup
OUT OF BUSINESS / M.I.A.
I prefer that meythod as well. But I usually only use 1 piece of 1X3 in the center of the hole. Shouldn't need 2 pieces of wood for a hole that size.
Cut the board AT LEAST twice as tall as the hole. Put a screw in the very middle of the board to use as a handle so you don't drop in into the wall :banghead
Screw 1 (only 1 this isn't rocket science) sry wall screw in the top and bottom of the hole into the board. Try to keep the screws an inch of 2 away from the hole so you don't crumble more drywall.
Cut small piece of drywall to fit into hole. Screw in place with 1 drywall screw (only 1 agian, too much will crak stuff) then mud it and sand it untill smooth.
Paint for taste :beer
i would do the same as fire guy mention but i also used two peices like david said. it is just a matter which is more comfortable for u. one or two.
I had to repair holes in my room when we moved into a new house. and the electical box was hanging around not mounted to a stud. fixed that all by my self. I like doing things with my hand and mind.:thumbup :thumbup oh i was 14 at the time. so if i could do it then i am sure u can do it too.
Speaking from experience?
BroncoBabe said:
Speaking from experience? :shrug
Never lost a piece of wood in a wall......
....But, other more shallow, moist holes :shrug maybe
:thumbup
I do most of the things I see on the home imporvemnt shows.
I full of all kinds of tricks. Just not a master of any of them :(
negative creep
yeah, those 13 year olds are real hard to get lost in:goodfinge
congrats on taken over the room mel:thumbup
1 - 15 of 15 Posts
