1 - 4 of 4 Posts
I searched the forums, and only found info on reprogramming Broncos newer than 92. I also found info on swapping speedo gears, but all those links were for automatic trannies (C4-C6 AOD...etc.)
My Bronco is a 90 5-speed (Mazda Tranny). I just went from the pitifully stock 235-75R15 tires to 31x10.50s. I was hoping there was a gear I could change or something. I know some Broncos came stock with 31s, so I didn't think this was a problem.
Anyone?
TTB Hater of course
G
Great taste in Bronco's dude! I got a 90 but swapped in a ZF 5spd. The light duty mazda worked fine until I built up my motor. It lasted only two weeks that (see signature).
The speedo cable has a VSS and gear on the end of it attached to the back of the transfer case. Pull the clip, pull the cable, and change the gear.
I have an extra ZF 5spd which has a 5.72 granny in it. It will get you rolling/crawling. See it here: http://cgi.ebay.com/ebaymotors/ws/e...3733&item=2453872960&sspagename=STRK:MESSE:IT
1 - 4 of 4 Posts
