I considered the coat hanger, but the opening isn't big enough for the axle and the coat hanger. He will have to pull out the bearings first, then that will work.bronco1 said:A coat hanger straightened out with a loop on one end big enough to go over the remaining part of the axel shaft at an angle. slide the coat hanger into the axel tube,then over the axel,the loop should be at such an angle that when you slowly pull the coat hanger out it jambs on the axel enough to pull the axel out.This is assuming that there is enough axel to grab on to.
Gotcha, but how are you going to get a 12" piece of broken axle shaft out through the carrier, while the carrier is still in the housing??? If you pop the bearing out, how hard wold that be to pop out the bearing and press it back in on the trail??Fireguy50 said:remove the cover and C clip
Take the carrier out. It's not that hard. Make sure you carry gear oil, or at least a way to capture and reuse the original gear oil. Also make sure you have all the tools you need to remove the carrier and cross shaft. also be careful to make sure you know which side the shims came from.crackhead said:Gotcha, but how are you going to get a 12" piece of broken axle shaft out through the carrier, while the carrier is still in the housing??? If you pop the bearing out, how hard wold that be to pop out the bearing and press it back in on the trail??
Dude, how about I give you a call when it happens and you can show me how its done.. :histericaslim said:Unbolt your axle housing from the springs and stand it up on its end and shake it out.:thumbup
Axles typically break at the most inconvenient place to get at them. Usually, they break at the carrier. I've seen guys carry a broomstick with a magnet on it. That works sometimes.crackhead said:Dude, how about I give you a call when it happens and you can show me how its done.. :histerica
When 8.8 shafts break, where do they usually do it?? Carrier end, brake end??
yes. I would say that more than likely you'll get the break at the splines, unless you are having bearing issues and it's damaging the thick azz outer shaft area, which actually necks up to about 1.62" dia, thicker than 35 spline shafts.Steve83 said:The weakest point is at the splines, but the highest stress is where the bearings ride. It should never break in the middle.
