1 - 9 of 9 Posts
How do you tell if the engine is misfiring? I just did the Six Litre Tune-up and gapped out the plugs to .055 and advanced the timing to 12 degrees. I had in fact advanced the timing before the tune-up and had more take-off power. I guess gapping out the plugs increased my power, but if it did the power is more on the top end and smoother. I don't get that throw you back in your seat feel. Things I haven't done are: put a new motorcraft coil on, new cap and rotor, or advanced the timing to 13.5. Im getting a motorcraft coil and a new cap and rotor. The wires and plugs are only a couple months old. My only other concern is I didin't get my the boots on a few of the spark plugs completely. I know they make a click, but a few made a very silent click I guess. Would it be very obvious how the engine runs if that was a problem?
Thanks-
If you can pull back on them and they don't come off with just a slight tug you're ok. If they weren't on right you WOULD know. It would run like dog shit.
A misfire or a loose spark plug boot? I could tell by how the engine runs? Its seems to have good power. I mean I guess a 5.0 is a small engine for our heavy trucks. I will see what a new cap/rotor does and the motorcraft coil. Plus, i will experiment with the timing a little more and going to 13.5 degrees.
Don't expect to get your head thrown back in your seat....be careful on the timing....leave it at 12.
Well, really the biggest gain im looking for is gas mileage. Why not try 13.5 degrees like the six litre tuneup suggests? And if I don't mess with the timing, I will see what a new rotor and cap does along with a new motorcraft coil.
you're not gonna get a whole lot MPG wise. synthetic fluids, free flowing exhaust, and foam air filter will get you best MPG gains, along with lighter right foot.
The bump in timing up 12 is actually is saving me a good bit of gas. I just wanted to see if I could get a little more out of it.
Okay, just replaced the coil with motorcraft and also the cap and rotor which had a good bit of corosion on it. Now, I actually feel the power gains from the Six Litre Tune-up. My timing is currently at 12.5-13 degrees BTDC. I don't hear any consistant pinging or knocking. But, sometimes there might be a random knock here and there if you listen closely. Should I leave it or back it down to 11 or so? My next move is to clean the throttle body on the engine.
1 - 9 of 9 Posts
