I spent all day reupholstering the headliner and painting all the trim pieces black. (looks SHARP) The PO had removed the foam board and headliner and I was replacing it with one from a JY ($15).
Anyway, when I went to remove the dome light, the black connectors that are attached to the power wires fell apart when I touched them. Alll that is left is a threaded insert and a little bit of plastic holding it onto the wire.
I know that one of the three screws attaches to the roof, and is the ground. The other two screws on the dome light attach to the threaded connector and provide power to the map lights and dome light. I assume the part of the plastic piece that fell apart somehow mechanically attached to the roof and helped to hold the dome light to the roof securely. I can see two little square cutouts, where I assume the connectors must somehow lock into.
First- are my assumptions correct and do I understand the way it attaches to the roof?
Second - If so, where can I get the connectors?
Third- if I can't get the connectors, how should I go about securely attaching the dome light to the roof and getting power to map and dome lights?
Thanks!
Thanks!
