Will the map sensor cause the engine to bog out when i put it in gear and give it gas if it the vacuum is hooked up wrong. Also could this be causing my fuel pressure to be low, its at about 30psi.
Yeah, if you didn't hook up the MAP right, all kinds of problems can happen.
No, it can't cause your fuel pressure to be low. Try changing your fuel filter.
No Map = No go. Without the Map your truck if you are lucky will go into limp mode, if it doesn't just die all together. Like some of the guys said before check your fuel filter & fuel pump - these are things that would most likely cause low fuel pressure.
