1 - 16 of 16 Posts
There really isnt a solid answer to that question given variables like:
Mileage driven
Driving conditions
Vehicle type
Life of individual parts, quality of parts etc..
· Satyr of the Midwest
I inspect the spark plugs, cap, & rotor about every 15,000 or so (two oil changes for me), and replace as necessary.
· a renegade of funk
I know to replace the caps when there is no contacts left and the rotor looks worn. any cracks, you should also replace.
what about wires? how do you check them?\
What about coils?
you can all ways ohm your wires
and the coil has has a bar code scanner that needs to be scanned and it will tell you the expiration date
It used to be a tune-up every 30,000 miles. With copper plugs, I would say they would be done by then, but as far as the cap and rotor and wires, I would just visually look them over.
· Kitteh Commandaar!
When it quits running good :toothless :goodfinge
I'd say check everything over every 10k miles or so. Change stuff out when needed. :shrug
KC
· Fullsize Member
It also depends on the quality of the parts you install. I dont trust any part enough to just let it go for say 50k miles. I check that stuff about every third oil change. I thought you would know this chit Need4racin...
· Former owner of Shadofax
"you can all ways ohm your wires
and the coil has has a bar code scanner that needs to be scanned and it will tell you the expiration date"
you trying to be a wise guy?
maybe on the latter part, never heard that. But checking resistance in your wires (ohms) is easy if you have a gauge. You can then compare to what should be decent for your length of wires.
Other than wires, I'm roughly with Sigepblue on cap/rotor/plugs on miles. My Jacobs wires have been in since 55k or about 10yrs so I can tell you they are good wires, and I should check them, but the've been perfect, and the truck is idling smooth, so I hate pulling on them when I don't believe anything is wrong with them. what a quality product they were.
so I hate pulling on them when I don't believe anything is wrong with them.......
And Steve83, don't go misquoting me on this, I know it's election time, but this would be taken out of context.:goodfinge:toothless
· Banned
Discussion Starter · #12 ·
I know i haven't met my quota on stupid threads.
· Banned
Discussion Starter · #14 ·
and the coil should show 12 volts.
I must of been bored when I started this thread.
I'm going to put this thread in honor of Rednek.
1 - 16 of 16 Posts
