In Front of Jopes
Is twice a year too much? I see it as cheap insurance as I go to school far away from home, and cannot afford to have a bearing failure as I never had one.
Charlie don't surf..
'92 Ford Bronco XLT
:stupid
Same here. But I would say twice a year if you're not seeing a lot of mud or water is probably sufficient.
im replacing mine this week along with rotors,pads and calipers.
at 230,000 and the only part i had too replace was the pads(about every 5,000miles) rotors are still in spec
after this i will be doing it alot more like twice or more a year
It's BTW Not AKA!
ANY time you go through water deep enough to cover the tires you need to repack you bearings in the front. I would also say at least check them every 10,000 miles.
