How to adjust AOD manual shift linkage?
1265 Views 3 Replies 2 Participants Last post by  El Bicho
I just installed a new tranny (I have another thread going about the noise it's making) and I think I'm not getting the linkage adjusted correctly. I followed the Haynes procedure, but I still have the feeling that it's not quite right. Anyone have any suggestions or alternate procedures?
Will
1 - 4 of 4 Posts
Are you talking the linkage that changes gear selections or do you mean TV cable adjustment?
The linkage to change gears. I've got the TV one ironed out, I think.
Steve83 said:
What's the "feeling"??? If it changes thru all the gears, it's right. The only other adjustment is the indicator in the cluster.
My other thread explains the problem:
http://fullsizebronco.com/forum/showthread.php?t=70842
I think it is adjusted correctly after all. I think there's a more serious problem. I was hoping that it just wasn't going into the detents all the way, causing some kind of mischief.
Will
1 - 4 of 4 Posts
