The 96 has 135,000, the ball joints need replaced, and I am checking if the tie rods need replaced. A friend told me if I got under the truck and could move the tie rods with a pry bar then they need to be replaced. So, I got under the truck today and tried to pry the tie rods up and down right near the outer part of the outer tie rods - no movement. Yet, where the inner tie rods meet I could take my hands and move both inner tie rods and I could see the outer tie rods moving in sync with the inner tie rods as I was moving the rods. Is the play in the tie rods like this acceptable? Do they need replaced or is there a better test?
Thanks.
A better test would be to have someone turn the wheel a bit side to side, and watch what the tie rods do. if one side moves and the other side of the joint doesn't, replace 'em
If it was me and I was going through the trouble of replacing the ball joints, I would just do the tie rods too.
That way, everything will be good and tight and you won't have to wonder about them.
Replacing both tie rods with the ball joints will save you on alignment costs. Tie rods are relatively cheap to replace (if you're doing it yourself).
I wouldnt do the tie rods if they were still tight and the grease boots in place. I dont ususally have it professionally aligned after tie rods, you can just measure it out to set the toe.
Tie rod test I ususally perform is to have someone looking from the front, wheel jacked up, grab it at 3 and 9 and shake it.
For the relatively inexpensive cost of a new tie-rod end, I'd say it was worth it.
