thanks. i always wondered how to double flare a brake line
I'm horrible about this myself. I tend to add 1/2 inch or so to most line lengths so I can cut off at least one flare because I forgot to put the fitting on. Most lines can handle the extra length if I don't screw up.MikE2 said:Few things I'll add, DON'T forget to put the fiting on first. There have been times I have had to cut the flare off 3 times untill I remembered to install the fitting. Also install it the correct way.
I'd be a little cautious of a kit that couldn't do what mine does: perform the flare on a straight cut end. I've used kits from all the big tool manufacturers and they worked without having to doctor the tube. Not sure why your's was different, but it would be worth digging into a bit. I suspect the anvils may not have been as good as they could be.81Bronk36 said:That was good, I did it on a worse vehicle, a Chebby Blazer so dont feel bad. One thing I noticed, it may have been my kit but it said to bevel the edges of the tube, I could not get the flare to colapse in without it, it would just superflare out.
When you buy the premade repair line, it will come with two fittings already installed on the pipe. Napa and Carquest will have brake fittings and unions available. I'm not sure if Autozone and others like them will have fittings or not.jermil01 said:Nice job Larston, did you buy the flare fittings from NAPA as well??
I have no problem replacing the fitting in the truck. You just have to be careful not to bend the line while you're making the new flare. The pics above were taken above the rear axle of an unlifted Jeep CJ5. There's a lot more room under the hood of a Bronco :toothlessFL78Bronco said:I want to install an F350 Brake booster/MC upgrade to my 78 Bronco, which will require me to change the line nut fittings on the front brake lines and double flare them in the process. Can this be done without removing the brake lines? What i mean is... if i take the old Booster/mc out, can i replace the nut and double flare the line without removing the front brake line from the truck or is it easy to remove this line to do it and then re-install it?
Thanks
Just using the roller type tubing cutter bevels the line enoufgh for it to flare correctly. You will see even with your kit, if the line was cut off straight, like with a saw and filed smooth, it wouldn't make the first flare right. If your using some very soft tubing, like copper or aluminum you have to file the bevel at about 45" otherwise instead of putting the first flare in the line it just comprersses it flat.Larston said:I'd be a little cautious of a kit that couldn't do what mine does: perform the flare on a straight cut end. I've used kits from all the big tool manufacturers and they worked without having to doctor the tube. Not sure why your's was different, but it would be worth digging into a bit. I suspect the anvils may not have been as good as they could be.
Mine was the one they sell at sears (performance tools or something) It was cheap, it said to bevel it in the directions and it didnt work untill I beveled it so it could have been the design of the tool???MikE2 said:Just using the roller type tubing cutter bevels the line enoufgh for it to flare correctly. You will see even with your kit, if the line was cut off straight, like with a saw and filed smooth, it wouldn't make the first flare right. If your using some very soft tubing, like copper or aluminum you have to file the bevel at about 45" otherwise instead of putting the first flare in the line it just comprersses it flat.
