1 - 14 of 14 Posts
MARBLE GARGLER!
I just got my axles from Superior and they have no studs in them, How do I instal the press in studs ? Do I have to bring them to a shop that has a press or can I just tighten a lugnut up to draw the studs tight ?
MARBLE GARGLER!
i will use a lugnut...... i will also tighten it...... thanks fellas-
Administrator
if you have the axle shaft out I usually install the stud...center a socket over it and knock it tight with a sledge hammer.
MARBLE GARGLER!
since its out .... ill be in the front yard whacking it.
ya ya thats what i do to keep it on there then once everything is installed honk them down with lug nuts then after you drive it a mile or so tighten any loose ones thats just what i do
It's BTW Not AKA!
If you are uncomfortable with beating the hell out of your new shafts take them somehwere and have them pressed in.
I'd suggest you try the socket/sledge hammer routine only if you're confident of hitting the socket/stud squarely. You do not want to misalign a stud and then try to straighten it by hitting it again. You can wallow out the hole in your new shaft and always have a loose stud. I've used a lug nut and an impact to seat the stud however I first seat the stud by hand and stack some washers on it prior to installing the lug nut. Ensure your impact socket is a deep well to ensure the socket doesn't limit out prior to the stud fully seating.
Geez, some of you guys make this sound like some sort of science experiment. :rofl: Pull them in with the lug nuts, smack 'em in with a hammer, use a press, whatever you got. Just be sure to recheck them several times in the first hundred miles or so as a couple will surely be a hair loose after installation.
1 - 14 of 14 Posts
