1 - 20 of 22 Posts
negative creep
park it next to the most ridiculous truck you've ever seen.....
lets see....blocks, mega springs, and blocks for shocks...
full hydro....pinion brake front....and a double CV...
more blocks....more shocks....
Bad MoFo
:wacko :wacko
It looks like a stiff breeze would blow it over. :toothless
And what's with those driveline angles? Tell me that thing can even drive 55 without shaking itself apart. :twak
Chaos is coming!!
I like the exhaust pointing right at the tire in the one picture:wacko
Doesn't look that bad. With CV's top and bottom the driveline would be smooth at any speed. Looks like he's got plenty of room on the slipjoint too, which would be needed with a driveline angle like that. I do like the axles, and the front springs look heavy enoufgh they should't have any problem with that spacer/block welded on there. Also a good idea to use the drop brackets instead of having the leaf springs arched that much, like I have seen some others do. And the back has the ladderbars to keep the wheel hop down. The hydraulic steering set up looks good too. Only thing I don't like is running one pinion brake on the street...but whatever....hydraulic steering is illegal too.
Kinda reminds me of the Blazer I saw up in Cornelia yesterday,it was leaf sprung,and I'm guess it was a chicks rig,on the front it had bad ass girls drive big ass trucks.
The Anti Yam!
Andy351 said:
how to make a bronco on 40s look small
Not the most rediculous I'v ever seen but it is in the top 50.
Bronkin' 'Round!
88 351/AOD/4” ProComp 94 351/E4OD/4” Superlift
There's a burban around here like that. Funny thing is there's no t-case or front driveshaft. Just a solid axle and a lift.
Call Me Ace
it looks like a beener wagon on a fancy lift setup... no way in hell id drive that...
ace
is FSB'd out
I can't tell from the pics, is that thing running 44's? Either way, to each his own. You'll never see me in one of those. I'd take the truck on the right any day.
1 - 20 of 22 Posts
