1 - 3 of 3 Posts
anyone have pics of how to remove the wiper arms off my vintage bronco? need to remove cowl to fix some leaks. it looks totally different than the tension type i am used to prying off with a screw driver.
take look at the bottom of the wiper arm, some have a little tab you must pull out to release the arm, but to do this raise the arm itself a couple of inches then pull out on the tab, you may need a small flat blade screwdriver to pry it out, sometimes there stuck, once you pull the tab the arm should just lift off
1 - 3 of 3 Posts
