I am having a hard time starting my f-350 and I was told to try ether, but I have never used it before so i just need to know where to spray it and how much to use. Just don't want to do something stupid.
It is a 99What year is it? To check the glow plugs on a diesel, you unplug them and hook up a test light to the + side of the batt. You then touch the glow plug where the electrical prong is. If it lights up, they are bad (grounding internally). This is USUALLY the case. I would say 99.9% of the time.
Chris
What is a CPS?99 psd, it is cranking but not starting is leading me to beleive your CPS has done shit the bed.
just because ether has been used to cold start diesels for ages does not mean it is safe now. glow plugs and ether is a bad combination.I have been told by a couple of people to try the ether, and I did. Nothing happened, didn't even start. I am not saying you are wrong in fact I am not going to use the ether after hearing your story. Any suggestions on how to get it started? It's plugged in(block heater) and is currently being recharged. How do I know for sure if it's the glow plugs? It started yesterday for a minute and hasn't started since. Cranks all day long but no firing.
not on a glow plug engine.you can use it but in small amounts, pretty much in a last resort effort.
heavy equpitment is a whole differnt ball game. I repeat do not do it on a PSD. there are reasons a vehicle has a hard time starting. bottom line! you should not have to use a starting fluid to "start" the truck. Ever thing of fixing it rather than just making do?well we do some times at the grain elevator that i work at. so you can do it. i operate heavy equipment daily, i know it can be done and i know the hazzards of such also.
yeah we use it to start a bunch of the cats at work all the time as well. But not on any glow plug engines.well we do some times at the grain elevator that i work at. so you can do it. i operate heavy equipment daily, i know it can be done and i know the hazzards of such also.
