To re-hash a question I posed yesterday.....I am trying to decide if I want to build my engine in the future to be NA or SC. I'd like to hear from both sides, especially those who have done either. I want to know details, especially relating to driveability and dependability of both systems. Give me your opinions, and I would like everything to work with what I already have. Any input is greatly appreciated.:beer
crank trigger
i think you have to beef up the motor quite a bit to be able to handle the forces of supercharging. might not work with everything you already have.
I'm not talking about blowing it with 17 PSI. You can buy a few different setups ranging from 5 to 9 PSI That will bolt up to the truck as it sits, from the factory. However, with 144K on the clock, I will go through the engine from top-to-bottom to go either route.
What are you considering when you say a NA engine? Stock or built for more power?
Normally Aspirated
This is from fordcobraengines site
302 with 315 HP / 325 lbs Torque
86-95 Ford Trucks Fuel Injected
50 State Street Legal
PRECISION MACHINED 302 ROLLER CAM BLOCK
MICROPOLISHED AND DEBURRED NODULAR IRON CRANKSHAFT
SHOT PEEN HARDENED CONNECTING RODS WITH 190,000 PSI ARP BOLTS
SPEED PRO HYPEREUTECTIC PISTONS 9.5 TO 1 COMPRESSION
SPEED PRO PISTON RINGS
3 PIECE DYNAGEAR STEEL DOUBLE ROLLER STYLE TIMING GEAR SET
COMP CAMS STEEL ROLLER RV CAMSHAFT
HIGH VOLUME MELLING OIL PUMP, SCREEN AND DRIVE ROD
EDELBROCK HIGH FLOW ALUMINUM CYLINDER HEADS 60 CC COMBUSTION CHAMBERS
1.6 TO 1 RATIO ROLLER TIP ROCKERS FULLY ADJUSTED
2.02 STAINLESS STEEL INTAKE VALVES
1.60 STAINLESS STEEL EXHAUST VALVES
HARDENED SEATS FOR UNLEADED OR REGULAR FUEL
HEAVY DUTY 1.45 DIAMETER VALVE SPRINGS, 7 DEGREE LOCKS
CHROME MOLY PUSH RODS FOR USE WITH GUIDE PLATES
NEW TRUCK REAR SUMP OIL PAN,
TIMING COVER WITH HARMONIC BALANCER
NEW CHROME VALVE COVERS WITH BREATHER CAP AND BAFFLES
HEAVY DUTY FLYWHEEL FOR AUTOMATIC APPLICATIONS
BALANCED, BLUE PRINTED, HAND ASSEMBLED
AIRTEX WATER PUMP
EDELBROCK ALUMINUM EFI TRUCK MANIFOLD
NEW ELECTRONIC DISTRIBUTOR, WIRES AND SPARK PLUGS
NEW 21 LB. INJECTORS
That seems like that would be a good kick in performance from the 199 HP that our engines were supposed to have new and probably haven't seen in years. I am tempted at some point to buy one of their engines or build one as close as I can. I would love some more EFI power for towing.
96ProjectBronco
