1 - 8 of 8 Posts
okay same 96 bronco with auto hubs.. my cam is stuck to my spindle, and i need to replace my rotor. the other side came wright off with a pick this side is stuck and wont come out. any ideasto getting this out? thought about a gear puller but i dont know if i can get it to fit inside the hub.
hopefully i can get this back together before next weekend i have a big fishing trip planned..
Are you talking about part no 20 in this picture?
Been a while since I've been into the 3 bolts so I'm not even certain as to what it looks like. But from my memory, everything usually comes apart fairly easy, including the spindal nut.
Can you post a picture of the part from the other side if it's still apart? I'm sure I have one of these pieces in my garage, I just got to locate it and see what it is.
yeah thats it... i got mine off i had to cut the hub off with a sawzall to chisel it off.. now i need a new hub and cam.. hopefully i can find one easy/quick enough
You'll be better off getting rid of those garbage hubs and getting set up with a set of manuals. You'll need a conversion kit also.
i always hear how they are better.. but i like to not have to worry about locking in and out.. and my wife drives he bronco in bad weather and i dont like the idea of her having to get in and out to lock and unlock the hubs.. or she may forget to unlock them
But see that's the problem with the auto hubs...........
if you don,t have posi in front and your transfer is in 2 wheel you can leave your hubs locked in like auto in bad weather it won,t hurt
1 - 8 of 8 Posts
