But do you have four of them?:shockedthats why i installed in the unimog axles in the jeep!
many of those had independent suspensions, didn't you see the "TTB" like drop look when lifted tires off the groundthats why i installed in the unimog axles in the jeep!
More like quad IFS...i'm pretty sure they're not running a TTB setupQuad TTBs!
COOOOOOOOOOOOOOOOOL!
Nope you are wrong. Deff 4 TTB front axles under there.:doh0715:More like quad IFS...i'm pretty sure they're not running a TTB setup![]()
Nope, you're wrong - the axle halfs are attached to that massive triangle pieces in the middle (they hold the differentials too), the axle ends near the wheels are secured from moving front-back by the leaf springs. There are trailing arms in the rear for the same reason we put them on our trucks, the tri-axles trucks don't have trailing arms on the single axle, and the quad-axle trucks may or may not have front trailing arms (most offroad-duty ones do, seen a few on-road ones that don't). Additionally, the driveshafts are placed inside those massive steel tubes that run from differential to differential, these tubes protect the driveshafts and also make the frame of the truck a horizontal triangular prism - that's why you see them going over huge holes like that with axles hanging in the air, a normal truck frame will bend under these conditions, but the 3D frames these beasts hold up pretty well. And in case you're wondering - those were designed as military transport vehicles, some equipped with air-cooled V12 tank engines and intended to haul, well, tanksNope you are wrong. Deff 4 TTB front axles under there.:doh0715:
Nope, you're wrong - the axle halfs are attached to that massive triangle pieces in the middle (they hold the differentials too), the axle ends near the wheels are secured from moving front-back by the leaf springs. There are trailing arms in the rear for the same reason we put them on our trucks, the tri-axles trucks don't have trailing arms on the single axle, and the quad-axle trucks may or may not have front trailing arms (most offroad-duty ones do, seen a few on-road ones that don't). Additionally, the driveshafts are placed inside those massive steel tubes that run from differential to differential, these tubes protect the driveshafts and also make the frame of the truck a horizontal triangular prism - that's why you see them going over huge holes like that with axles hanging in the air, a normal truck frame will bend under these conditions, but the 3D frames these beasts hold up pretty well. And in case you're wondering - those were designed as military transport vehicles, some equipped with air-cooled V12 tank engines and intended to haul, well, tanks![]()
