DAMNIT! I cant get in my glovebox. No, its not locked, And im afriad to pull because i'll break it! DAMNIT, What do i do? I Need to get some papers outta there and check something!:twak :shrug :shrug :cry
If you had an '80-86 you could remove the cardboard section from under the dash....not sure on the "newer" ones....try prying it open carefully with a screwdriver....
crowbar it out or use a ford wrench (aka a big ass hammer) i mean if somethings going to break its probably just part of the little open mechanisim and im sure that will be like 3 bucks to replace...if that
My glovebox in my old 83 got stuck once. I got it open with a big screwdriver...but I had to break the lock. Maybe someone else can give ya some better advice.
if you really want to leave the dash pretty well intact, i would drill out your latch through the key hole and then just replace that, if it doesnt open it sounds like it needs to be replaced anyway...
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
